Frage Click-lock for Gas tank filler flap
  • Warburg
  • Warburgs Avatar Autor
21 Mai 2012 21:50
Hello Andreas,
Thanks for the tip. I will try the rubber foam and wait for the real part from the club later this year....
21 Mai 2012 16:59
Parts are under construction at the German SM club. Maybe end of the year? Meanwhile use a little rubber tube for the same part. Or some rubber foam.
  • Warburg
21 Mai 2012 16:47
Gents,
Does anybody have a solution for replacement of the "Rubber springs" in the Click lock for the gas tank filler flap?
The Rubbers are necessary for the flap to open after pressing the flap.
If no spring, the flap stays inside and can only be opened by means of very long nails :) or other small tool.....
forum.citroensmclub.de//img/datei_1337610896.JPG
Best regards
Carsten Warburg
